Brake master cylinder
don.giannis
Wysłany: 2024-03-28, 17:48   Brake master cylinder
Hello everyone. It's me again.
I would like to know what are differences between master cylinders from first 126 series and second ones? Would it be okay if I install new master cylinder for 1st series to my 1987 Fiat 126p?
I ordered this one but I think it's the wrong one and will not fit.
https://shop.wum-autoteile.de/epages/WuM-Autoteile.sf/en_GB/?ObjectPath=/Shops/WuM-Autoteile/Products/308104
I hope you'll understand me what I mean.
Thank you for your responses.
Daniel22
Wysłany: 2024-03-30, 00:41
Look for TRW PMF182 .This is how my friend and I solved the problem of weak brakes in his 126p. Many modern substitutes are shoddy and do not work properly. The TRW pump works very well, you only need to change the brake pipe ends or install adapters - the TRW pump has a different thread than the standard 126p. But it works, which replacement pumps unfortunately do not guarantee.
Wysłany: 2024-04-07, 13:27
don.giannis napisał/a:
Could You please explain differences? It looks OK. Probably someone has exchanged the pump to part from Fiat UNO?
