Interesting headlights!
dagleykd
Wysłany: 2016-12-09, 21:45   Interesting headlights!
Hi all!
Was looking around at the information for the 126's headlights and came across these:
http://www.grote.com/prod...orward-lighting
They weren't designed for the 126, but they are roughly the same 5 inch X 7 inch size the 126 uses for it's headlights. This Grote light's size is about 5.2 X 7.5 inches. They are LED with built in LED amber lights, plus they come with an adapter to connect to an H4 connector like the later 126s have, so it make for an interesting replacement if there was a way to mount it! :)
klink
Wysłany: 2017-02-18, 23:08
DOT compliance could be nice for people in countries where it applies.
Aside from that, I might change a bit the look of the car. I switched to LED lights on my maluch with more regular H4 ones as described (in French, sorry) there https://fiat126maluch.wordpress.com/2016/10/02/remplacement-de-leclairage-a-filament-en-led/
lubelak.nl
Mi to VOLVO....
Wysłany: 2017-02-19, 10:22
the cost of such lamps is $ 220, but in Poland you can buy for like $ 20
http://allegro.pl/reflekt...5852755290.html
http://www.ebay.com/itm/7...8VUuvfH&vxp=mtr
Łoś w Maluchu.....
dagleykd
Wysłany: 2017-02-19, 19:59
lubelak.nl napisał/a:
Those LED Halo lights are quite nice! Are they hard to mount in the 126?
