searching for an ELX exhaust / tłumik katalyzorem
klink
Wysłany: 2015-04-17, 16:31   searching for an ELX exhaust / tłumik katalyzorem
Hello,
I'm wondering how come I cannot find a single ELX exhaust (with catalysor) on allegro.pl while I can easily find exhaust for FL and EL.
Any clues? How to find such exhaust?
Wysłany: 2015-04-17, 18:17
http://allegro.pl/tlumik-...5132837811.html
This is a exhaust type for EL/ELX - with "something" called catalysator :)
'72 ZAZ Zaporożec 966 #1
klink
Wysłany: 2015-04-17, 20:17
Turns out it's EL one, not ELX.
I contacted people around, told me that ELX katalyzorem exhaust was too expensive (600 zł) so nobody made any benefit producing it, since EL exhaust works and is cheap, hence the fact is nowhere to be found.
buh
Wysłany: 2015-04-17, 20:29
Yes that's true. Catalitic convertor is no longer available, anywhere.
Honestly i never saw any to buy.
Why you searching for that type of exhaust ? Any problems with emission control ? :E
I think there are some universal catalitic convertors, but i really doubt it could fit between exhaust manifolds, and muffler.
Anzel - ten tłumik nie ma katalizatora. Nie wprowadzaj ludzi w błąd.
Pussy Wagon
klink
Wysłany: 2015-04-19, 15:47
Domage napisał/a:
Exactly.
I wanted to check if it was doable to register a maluch from around 93 in western countries. A car produced in 93 needs to pass euro 1 ( https://en.wikipedia.org/wiki/European_emission_standards ) - but only ELX actually pass euro 1, not the FL and not the EL. So it's not possible. You have to wait for the car to be considered as a collection car to be able to import it by the book.
xlar1
forumowy elektryk
Wysłany: 2015-04-20, 15:04
Hi.
Even in PL you have no chance to buy a new one as Domage, has written. The only way is to buy good quality part from EL and remove (cut out) the metal pipe that goes into the exhaust mainfold.
Unfortunately this solution will not let You pass the emmision control.
Domage napisał/a:
I think that there is a possibility to put it to ELX but it's a lot of welding to prepaire new shape of pipes between the mainfold and the catalytic convertor and to the muffler.
Problem z siecią?
Xlar Tech Serwis
