Warsztat - MMOEXP 12 Must-Know Tips and Tricks for ARC Raiders
Joenwalker - 2026-06-01, 05:46
Temat postu: MMOEXP 12 Must-Know Tips and Tricks for ARC Raiders
Introduction:
If you want to survive longer and farm more efficiently in ARC Raiders, these 12 tips will help improve your combat, mobility, and progression.
You can also buy cheap ARC Raiders Coins from MMOEXP for faster upgrades and gear progression.
1. Turn Comet Igniters Into Grenades
Comet Igniters from comet events can be used as throwable explosives.
Why They’re Good:
· Strong crowd control
· Effective against ARC groups
· Fun alternative grenade
Warning:
The explosion can bounce unpredictably and damage you, so always throw from a safe distance.
2. Access the Two-Player Secret Room Solo
Normally this room requires:
· A repaired lift
· A second player
But solo players can bypass it using a barricade.
How:
(1)Reach the upper ledge
(2) Place a barricade at an angle
(3) Jump onto it
(4) Breach the door
(5) Dismantle the barricade afterward
Benefits:
· No teammate needed
· No lift repair required
· Great solo loot method
3. Barricades Counter ARC Turbines
Barricades are extremely effective against ARC Turbines.
Tip:
Stay close behind the barricade during attacks to block heavy damage.
4. Don’t Shoot ARC Turbines While Flying
Many players waste ammo shooting airborne Turbines.
Correct Strategy
Attack only when:
· Blue lights appear
· Mines deploy
· The Turbine lowers
· Weak points are exposed
Best Targets:
· Yellow canisters
· Use high-damage weapons like the Hullcracker
Grounded Turbines take far more damage.
5. Combine Power Descender + Crash Mat
This combo lets you safely drop from very high areas.
How:
1. Throw the Crash Mat
2. Use the Power Descender
3. Land safely
Excellent for fast travel and emergency escapes.
6. Throw Crash Mats Mid-Fall
You can deploy Crash Mats while falling.
Benefits:
· Reduce fall damage
· Save inventory space
· Escape dangerous situations
Timing takes practice but is very useful.
7. Delay Project Completion Before Wipes
If a project overlaps with an expedition wipe:
· Leave objectives unfinished
· Complete them after the reset
Why:
You instantly gain:
· Blueprints
· Materials
· Gear
· Early progression rewards
Great strategy for new expedition cycles.
8. Best Mushroom Farming Route
The Dried Riverbed is currently one of the best mushroom farming areas.
Search Around:
· Fallen logs
· Broken branches
· River debris
Average Yield:
· Poor runs: 4 mushrooms
· Good runs: 6–10 mushrooms
Fast and reliable compared to contested farming spots.
9. Loot ARC Carriers
ARC Carriers can drop valuable endgame materials like:
· Turbine Compressors
· Vaporizer Regulators
Useful for fighting:
· ARC Turbines
· Vaporizers
· Advanced ARC enemies
Always breach them if possible.
10. Power Descenders Improve Flying ARC Fights
Very effective against:
· Rocketeers
· Vaporizers
· ARC Turbines
Advantages:
· Easier repositioning
· Safer aerial combat
· Reduced fall damage
One of the best utility tools in the game.
11. New Rusted Gear Farming Location
If Generator Hall feels inconsistent, farm the Controlled Access Zone instead.
Loot:
· Red containers
· Storage crates
· Building containers
12Results:
Players often get:
· 2–3 Rusted Gears per run
Currently more reliable than older locations.
12. Hurricane Raids + Power Descenders
Power Descenders are extremely strong during Hurricane Raid events.
Benefits:
· Faster traversal
· Better repositioning
· Easier access to high terrain
· Faster escapes
Perfect for aggressive movement-focused gameplay.
Final Thoughts
These strategies greatly improve:
· Solo survivability
· Farming efficiency
· Mobility
· Boss fights
· Expedition progression
The three strongest utility tools right now are:
· Barricades
· Crash Mats
· Power Descenders
Mastering them can dramatically improve your ARC Raiders experience. Players who want faster progression can also get cheap ARC Raiders Coins from MMOEXP, and use the 5% discount code “pizza” to save even more while improving their overall gameplay experience.There's also a discount code specially prepared for players: "pizza", offering a 5% discount.
